W
woody777
So, I read this thread:
https://homerecording.com/bbs/showthread.php?t=256127&highlight="recording+level+volume"
And visited this site: http://www.independentrecording.net/irn/resources/metergain/index.htm
And I still have a few questions... more directed at my particalur setup and where my levels should be while recording.
I have a Focusrite Saffire PRO 10 i/o. Here is the spec in question (I think):
Nominal output level 0dBFS = 16dBu, balanced, +22dBu globally switched with external PSU connected across all outputs
According to Independent Recording, to find the desired dBFS level to record at, I take the dBu level (16dBu or 22dBu in my case), subtract the line level (+4dBu or -7.8dBu [-10dBV] - not sure which I have???), and make that number a negative.
So, I'm looking at -12 dBFS in 16dBu mode or -18 dBFS in 22dBu mode, assuming my unit is +4dBu line level input.
Am I correct in this so far? How can I figure out if I have a pro +4dBu level or consumer -10dBv level? Or should I just not worry about it and shoot for average levels of -18dBFS?
Here's a link to my unit: http://www.focusrite.com/global/products/saffire/saffire_pro_10_io/ (specs are at the bottom)
Thanks... I just want to figure this out before I get too heavy into tracking!
