Gear_Junky
I am finishing a friend's squier strat after shielding and installing a humbucker and i also switched to a lighter gauge (9's), so had to tweak the truss rod a bit and set the intonation.
i am fairly familiar with the standard adjustments, all the parameters seem fine now - there's a nice little gap at 8th fret when string is depressed at 1st and last frets. the actions is fine, too.
but there's a nasty little buzz around the 18th/19th frets - it's actually a buzz at 18th and 19th just sounds like 20 (so either 20 is too high or 19 not high enough, right?). BTW, this only happens on high E string, all others are fine.
or could it be the high E bridge saddle being too low? it doesn't seem too low, but who knows?
this strat was professionally set up over a year ago and as long as we used the same gauge strings, there were no issues (although maybe i didn't notice).
how do i tell that it's definitely a fret height problem and what are some remedies?
Thanks!
Thanks!
HIGH RISK OF TRASHING OUT GUITAR
