P
phwree
Is it worth to spend $600 on Audition (2.0)? Or should I look for a cheaper, simpler program. (I trialled Audition, and liked it).
It works just fine with my Audition 1.0 and the M-Audio Delta 44. If the recording has a 16 bit quantisation, there is probably a poor resampling going on. This happens when I set a different sample rate in the M-Audio control panel than that in Audition.And no direct 24-bit recording
I'd basically just be working on up to 8 tracks, mixing them, adding effects, that kind of stuff.
I have tried reaper, and couldn't just fluke my way through it, so therefore didn't like it all that much![]()
I've always liked Audition (1.5) but in no way is it worth anywhere near $600. It doesn't even support MIDI/VSTi's. And no direct 24-bit recording, which isn't as big of a deal but it's a pretty basic feature you'd expect from any DAW, even more so, one for $600.
Try Reaper and see if you like it before spending a significant amount of cash on a DAW when it could be spent on something else.
http://www.reaper.fm
There's other programs like Cubase and Sonar also, which are more expensive but at least their price is warranted. But as far as I know, Reaper can do everything those other apps can do.
Danny, please don't spread misinformation.
Audition does support 24 bit 96K recording, I do it almost daily.
Audition does support 24 bit 96K recording, I do it almost daily. Yes, it doesn't support MIDI or VSTi production. It's not a sequencer like Cubase or ProTools. It's not intended for that. It's a recording/mixing/mastering platform which supports VST and DirectX plugs from all major suppliers. Nothing more, nothing less.
And to the OP, I don't know where you're getting $600 from... I see it in many online stores for $350 or less. You can Ebay an older version (I still use 1.5 as I don't like 2.0 ) for under $100.
Misinformation? By that, do you mean how in the recording options you have a choice between 16 bit and 32 bit float? And by how if you choose 32 bit it uses more CPU than is necessary? And how even in the file properties window, it says 24-bit, the file was recorded in 32 bit?
Ok...I'll try not to.
Oh, and who mentioned 96KHz?![]()
