H
hip-pop7
I use pro tools m-powered 7, so if some1 could share the standard operating procedures of mixing in PT MPs or tricks of the trade to get a quality master?
SALUTATIONS.
SALUTATIONS.
Might as well just cash it in while you're ahead.Experience and a good ear are a must.
I think you should just give up, because it's obvious if you don't know how to get stuff to sound good by now ... you probably never will.Might as well just cash it in while you're ahead.
SALUTATIONS.
There could be any number of a thousand different reasons for clarity - or more often, loss of clarity. Mic/pre quality, converter quality, clocking quality, tape/tape head quality, room quality, etc.No kidding.
I asked about clarity.
Not about producing a million dollar CD.
I hear people on here all the time with clear recordings and only using $1000 worth of gear.
if your running cables longer than 20ft.....then you really want good quality cables so there is no signal loss, or any degrading of the tone or signal......
some decent cables for the $$$ (not to expensive) are Canare, Mogami, and Monster.
Track normal, but "mix" Low (leave some headroom). When mixing lower......you can always Bring the volume back up in the Mastering stage.
Makes sense because when we track low and then up the volume there is a lot of hiss. Removing the hiss probably removes high end freqs hecne loss in clarity.![]()
Based upon the context and the time stamps, I'm assuming you're referring to my post re gain structure.Im willing to bet that has much to do with it as I have no clue about that.
I use some of the same gear as people at the tascam forums and they get much nicer results. Ive never read a thing on what you just said though.
