_brian_
Member
I recently downloaded the Cakewalk sfz host, I'm having problems with it. I require multiple channel output, however sometimes this does not work. Most of the time only the main stereo outs appear on cubase. A memory warning comes up saying there is not enough memory to load the selected soundfont - which is complete bullshit.
I found a workaround for that, just changing the mode to anything but sf16 or sf32 - then everything loads. However I do have a problem still with getting multiple channels to work.
I have read several people having the same problems using this under Windows 7 64 bit, so I'm fed up with the program and would like to try another one.
Can you recommend any other soundfont VST hosts? I require multiple out and instrument support. I don't need any internal effects etc.
Thanks
Thanks
