Yeah i figured nin was influence it sounds remincent incorporating some of the attention to detail and electronic sounds. i would have to rate nin as one of my favourite bands along with ministry.
You have better equipment that me damnit. I am beginnnig to think that i do really need more to create the sounds i need. I have
a yamaha cs1x synth and a guitar + boss vf-1 guitar effects.
I would disagree about pod sounds being weak for industrial. ok i don't have a pod but i have used one a reasonable ammount. yeah the straight up sounds will not cut it, but with some tweaking you can get a nice sound, and then in addition double tracking guitars and panning them half left/right hugely fattens out guitars, using a different sound for each channel. another technique which i use all the time is to use fuzzbox plugin for cubase, it comes as standard with my cubase (not sure about v5) but it is nothing special (my friend asked me to desribe its sound, i said "nasty sounding digital fuzzy disortion!"). I usually have three guitar tracks for each main riff, two panned hard left/right on different sounds, heavy distortion scooped mid style from
my boss vf-1 and then a third channel , a copy of one of the others tracks applied with the fuzzbox (any digital distortion should do, the overdrive and distortion that come with cubase 5 should do the job, although i do love the fuzzbox) and pan that centre. the fuzz track adds the extra industrial edge needed, play abuot with levels until it sounds fat.
Industrial metal is versitile in the sounds because they do not need to be clean sounding or anything, so the fuzz works ideally. That should get you a nice industrial metal sound, so start working on that new track and post it when its done so i can have a listen!
you can also use the pod to dirty up some synth sounds and get some cool sounds out of that, get a pounding drum bit with a touch of distortion and you are there!
I look forward to hearing more. Do you recommend any particular of your other tracks? i'm not intereested in the drum & bass track, i couldnt comment usefully on it.
I'll let you know when i've got some tracks worth downloading if you'd fancy a listen.
on a different note...
what do you think of ministrys- land of rape and honey, lot of people say its shit but i really like it i think it is excellent, bit less accesable that many others but cool none the less.
cheers
nick
