Blue Bear Sound
Vocals
I was curious as to the C1, 4033, and NT2 as far as vocal use, so here it is...
The Context
1 - Yes, that's me singing (and no, I don't plan on making a career as a vocalist!)
2 - Yes, all three mics captured the fact that I have a head cold perfectly! (ie, the nasal tone in certain sections has NOTHING to do with any mic characteristic!)
3 - No, I don't have perfect pitch (and I don't care - and neither should you - that's not the point of this!)
4 - Yes, that's a karaoke backing track of Pink Floyd's "Comfortably Numb" (what, you think I have time to put together an arrangement with session players specifically for this???)
5 - Here's how I worked the tracks to make them sound reasonable in the mix and still allow some sort of useful comparisons -
7 - Yes - these shoot-out comparisons are highly subjective, if you don't like the context I did it in, then don't download the clips, or do your own f*cking shoot-out!
8 - Commenting on how subjective and useless these shoot-outs are will just piss me off (since I did mention the context right up front!), and really helps no one ('cos people will still download the clips and make their own conclusions anyways!)
Now have at it............
Bruce
http://207.176.147.104/bbs.nsf/c558...5885256b5b002d33d5/$FILE/MicShootout3_MP3.ZIP
The Context
- - I tried to sing each track as similarly as possible for each take, and all the tracks were done after a good "warm-up period"... there are minor differences in delivery but no one should have any problems differentiating delivery from mic characteristic (if you can't, then which mic is which won't matter to you anyways!)
- I tracked each mic with the exact same signal chain - adjusting only for level consistency.
- I determined the appropriate effect/processing chain for the vocal track, then routed each mic thru it - each take had EXACTLY the same processing applied (except for the odd mute of certain delays, which I was doing at mixdown - it won't affect anything).
- listening to the character of delays also gives clues to the character of the mic - I noticed difference track to track and the only difference was the mic track being used.... which changed how the delay came across in the mix.
Bruce
