W
White_Rabbit
Ok, just so you know, I *have* read a few posts already where people have talked about the using the inserts on the MG already, but I want exact clarification on the following issue before I go and spent up. Oh, and I read the manual too, but it wasn't the most helpful piece of literature I've ever gazed upon. Anways...
Basically, I want to use the inserts on a Yamaha MG12/4 as "direct outs" to go to my Delta1010LT. To do this, I was going to use an 8 core RCA to 1/4" snake, but I get the feeling that the TS plugs on the snake will be unsuitable for "tapping" the inserts (that thing where you put it in half way). Should I be looking for a snake that has TRS plugs, or do TS plugs work for this purpose? Also, it doesn't matter if doing things with the TS snake will "steal" the signal from the main path, as I won't be using it to monitor or anything, just to record. Any help will be greatly appreciated!
Thanks in advance.
PS: This is the snake I'm looking at, for reference purposes: http://www.musicianswarehouse.com.au/default.aspx?Pg=21&ProductCode=CPR802
Thanks in advance.
