rightbrainnow said:
I have limited space. I can either record drums in a 8X12 room with 8 feet ceilings, a 16X20 room with 6'6" ceillings, or think about selling my drums mics to get an electronic drum set. I really dont want to use an electronic drum set as im starting like the "art" of drum miking....and acoustic drums just feel better. My space is lacking so bad though to come out with a quality recording...are 6'6" ceilings much different from 8 foot ceilings? These are the ONLY spaces I have to work with...
An 8' celing is totally doable, not a problem at all.
But now that I think about it - I might be able to deal with a 6'6" ceiling in a drum booth. I mean, my overhead microphones are only about 6' off the ground, so I'd just have to maybe lower them a few inches, but I would have to deaden at least some of the ceiling directly above the kit because that low ceiling slapback would suck royally.
Do you you have the option of trying the room out? If so, all you need is two or three mics. Put one directly over the drummer as high as you can, and aimed straight down on top of the kit, then go out as far from the kit as you can and aim one at the kit.
Then close mic the kick and snare. Don't add anything - meaning EQ, or effects - to this, and record each mic onto it's own separate track.
The goal is to see how bad the room effects the drum sound. Now that I'd thought about it for a few minutes, I'm betting the ceiling wont effect the overhead mic, as bad is it would the mic's out in the room.
Whatever you do, for God's sakes don't use any kind of cheap carpet or bedding foam for soundtreatment! Remember the Great White clubfire.
Tim
