J
JimenyW
I've been recording for the last couple of months on a Concord 444 Stereophonic 444 Reel to Reel. Over the last couple of days I've been experiencing some intense wow and flutter. I've cleaned everything in the tape path. I've even replaced the tape with new tape, thinking that might've been the problem. It wasn't.
The machine is usually good for the first twenty minutes it's on, then the wow and flutter starts.
From what I've read online it looks like I probably have to replace the pinch roller or the belt. Does this sound about right? The pinch roller looks like it's still perfectly round, though the color has turned a little red around its circumference.
Also, someone suggested I use rubber rejuvenator on both the belt and pinch roller, thinking it might get some life back into them. has anyone had any luck with this?
And finally, is it expensive to replace these? Are they easy to find?
Thanks for your help in advance.
