Worried about frying my sound card
  • Thread starter Thread starter wascally_wabbit
W
wascally_wabbit
I'm trying to hook up my guitar to my (onboard) sound card's line in jack, and therefore am building a preamp (there are a few designs I've picked out... Stratoblaster, AMZ mosfet booster, Utility Boost... but that's not really important).
My only worry is that I will manage to destroy my sound card somehow -- is this fear baseless? For reference, the design that I'm planning on using gives a maximum gain of about 35dB.
Hopefully I'm on the right track here, and not acting too much like the newbie I am :P
PS: I'd rather build a preamp myself, instead of buying one, because
a) I'm a cheap git
b) It'd be a good learning experience for getting into audio recording and interfacing and whatnot
-Thanks in advance (and I hope I'm not posting this in the wrong place, or this was already asked, or is irrelevant, etc...)
A proper preamp should take your HI-Z guitar (instrument/mic level) and transfer it into LOW-Z (line level). That's part of what a pre does! Shouldn't blow your card, but I would say be careful what you're building! Make sure your pre is actually a pre in this sense, and not just a Overdrive unit.
Jacob
Kind of cool to build your own pre.
The main problem with going into the computer through the line in jack is the quality of the A/D converters in the stock internal soundcard. For less than $200 you can get a USB interface like the Tascam US122 that has pretty good preamps and converters (way beyond what you'll find on most stock computer soundcards), line-in capablility, direct monitoring and inserts for processing.
Tim
Ummmm... line level is often an unbalanced high impedence signal.
Tim
I'm not too worried about the quality of the sound card's A/D converter... I just need something better than a fuzzy as hell guitar->line-in set up that won't blow up my computer (...and costs little-to-nothing) :P
jkokura said:
Have I got it backwards then?
No, just partially. There are low impedence balanced line level signals and high impedence unbalanced ones.
Tim
Tim
Ok....so then it's just taking an instrument level and making it a line level, and not Hi-Z to Low-Z? But an instrument (guitat) puts out at a Hi-Zlevel doesn't it?
Jacob
Elec gtrs generally put out high Z unbalanced signals.
Impedence is a different thing than level (voltage) though.
It's likely that the stock soundcard in the OP's computer has an unbalanced input, and if so he'll need a pre with that type of output.
Tim
