Jpwikid
Ok, I'm no electronics wiz so I need a little help wiring 2 cabs.....I have an Avatar 2x12 with celestion G12T-100's cab that is presently wired in series with 2 - 4 ohm speakers.....I metered it and that' s showing an 8 ohm output....That cab has an output to plug into another cab.....The second cab is an Avatar 2x12 with EV SRO's, the white alnico coffee can magnets which sound oh so sweet, that are 8 ohms...I haven't taken the back off yet but my meter is reading 16 ohms so I'm guessing their also wired in series...So, there lies my problem...I have an 8 ohm cab and a 16 ohm cab...I would like to run them together but with my setup it seems impossible...My head can switch from 4,8, and 16....With the 2 cabs running together now I'm getting around 6 ohms...I'm running my head on 4 ohms with the 2 cabs now but i would like to get the cabs matched properly....The only solution I've come up with is to run a resister on one of the cabs to either add or subtract ohmage...Again, electronics kinda escaped me in high school, along with a few other subjects , so any suggestions would be appreciated....Also, it would be nice to get some actual assisstance besides buy a 4x12 cab or just use one cab .....I actually have 2 heads and can split the cabs up, I'm just looking for other options with this configuration....Ythanx
