F
fishkarma
Right this should be simple but I have probably over thought it and have confused myself...
Marshall 2203 Amp jcm800> Mono speaker cable> Cab.
Sounds simple, is simple.
My confusion:
I have a TS jack going to a TS jack there are two wires on the speaker cable from wiring speakers before I take it I can solder tip to tip and sleve to sleve and should be safe.
From wiring guitars before I know that the sleeve is used for sheilding and a mono signal is passed down the tip.
I also know many guitarists use regular guitar cables to go between the two so although I know you do not use a guitar cable (due to their incapicity to handle the power) I know that the signal gets sent fine down one of the cores and thus the confusion of why don't these cables require two cores to get the speakers working like a regular amp (non guitar amps).
Am I safe to wire tip to tip and sleeve to sleeve like I think or should I ignore the sleeve as it would be grounding for the sheilding which I dont have on the cable and just wire tip to tip?
Maybe you can see my confusion, Maybe not. I can see my stupidity but I figure its better to be safe rather than sorry, personally I'd say its tip to tip sleeve to sleeve...
Cheers for any help/clarification
-Josh
My confusion:
-Josh
