C
cantthinkofname
Active member
i've been researching accoustics and keep hearing that foam is bad although haven't heard why. is it, and if it is why? Thanks in advance
foam isn't bad, but guys lining (close to 100% coverage) their room and then saying they've treated their room or even better, they have a dead room, is bad.
but don't tell them, because they will argue with you all day long and then go on about how great and balanced it sounds.
But you can't just use bass traps and diffusers and nothing else? Or can you? The lows will be out but what about the highs and mids?
Fiberglass is better in every regard.
It performs well when it's applied as designed and its limitations are understood....foam has poor performance where it really counts and ITS MORE EXPENSIVE.![]()
