ausrock
You know, you've waffled on so fucking much that I don't even know what it is you're trying to say any more
Which often is THE 'ultimate objective' of waffling.... I don't even know what it is you're trying to say ...
.correct me if I am wrong here, anytime you digitally eq, filter, adjust volume, mix etc.. , the said file needs to be reprocessed for every adjustment.
No, not unless you do your edits destructively, which no DAW program I am aware of is set up to do
Why can't digital-o-philes simply say: "digital is perfect" and leave the analog-o-philes alone cooking themselves in their own juices sqeezed from a load of fallacies and outright errors about digital "technology"
"Do digital oscilloscopes differ in their accuracy from analog oscilloscopes?"
I could bang out a simple ideal digital EQ filter in 15 minutes, which no one would probably use on account of its extremely boring sound.
Is the Revox as good as a true mastering-grade deck?
that was on a thread where the OP (a working musician) wanted a $500 total budget solution for producing CDs for audition. How does the Revox possibly fit in that scenario?
Let's discuss sample rate. [snip]
I note a disturbing tendency here to completely reject any attempt at scientific measurement whatsoever. That is a travesty.
I am also increasingly disturbed by frequent claims from tape aficionados to possess not only above-average but ultrasonic hearing.
], it is still an incomplete / distorted picture [of the 'in'], no matter if the output has now been converted into an analogue signal. It's still the analogue of a sampled sound. Frequency range, flat frequency, S/N ratio, doesn't mean absolutely anything, cause it's all about the missing 'in-betweens', that sampling, unfortunately causes. That, I believe, is the reason why many find digital sound objectionable. That plus the brick wall limiting of frequencies which should all be present, whether heard or perceived, just as nature intended.Hello all, I'm the writer of the aforementioned article
Ethan, have you read the write ups about "The Emperor's new sampling rate " double blind tests? I thought of you when I read them.
Cheers Tim
Hello all, I'm the writer of the aformentioned article that's caused so much controversy and can't help but feel a bit flattered.
I admit that my initial experimentation was flawed in that I had only used sine waves as my base line for comparison. However, real music and alternate waveforms, though harder to measure are much more significant for listening experiments.
My article also only covered the scope of what happens in a purely digital world. Later experiments would show that a whole new world of problems are created when converting from digital to analogue and vice-versa. But I digress.
Whether you process destructively or nondestructively, the same processing happens. A simple change of volume by .1dB requires every single sample to be re-estimated.
Cutting 100Hz 1dB requires hundreds of delays to be processed and combined with every sample. No matter if you using destructive or non, 24-bit or 64-bit, you WILL introduce distortion, comb filtering and aliasing.
Yes they do. Greately as a matter of fact. I prefer analogue scopes for some things and digital scopes for others. But it takes about 8x the bandwidth for a digital scope to get the same accuracy for high frequency analysis that an analogue scope does. Then again, I hate following that crawling dot on analogue scopes to examine low frequency stuff.
Not just boring but incredibly harsh and unnatural. Trust me, I've put up with a decade of bad digital EQ. It's only been recently where some decent ones have been put to use. It's not just a matter of emulating artefacts of analogue EQs. In fact, my favorite digital EQ could never easily be created in the analogue world. Likewise, none of my analogue EQs could ever be truthfully recreated in the digital world. They're just 2 different beasts. But this digital EQ I almost like is incredibly high resolution, incredibly accurate, incredibly power hungry and incredibly expensive.
My recent experiments involving square waves showed significant audible distortion as low as 2KHz. Massive phase rotation, aliasing as high as 6dB below the fundamental frequency and increased output level is normal in this condition particularly as you get NEAR the Nyquist limit.
In the case of complex music and the like, the errors are greater than the accuracies.
Now if nothing above 44.1KHz was necessary, then why do ALL modern DACs use oversampling? Because those hard, brittle, steryl sounding digital recordings of the 80s proved to us that 44.1KHz was NOT enough and we had to figure out how to fill in the blanks.
Furthermore, people neglect the word-length's contribution to aliasing. An 8-bit recording at -6dB nominal shows significant audible distortion and nobody will argue with that. Now you extrapolate this into the 16-bit world and the same rule applies. Every detail at -54dBfs will have the same distortion in it as the -6dB 8-bit sound did.
I dare you to get an original CD release (not the remaster) of The Police "Synchronicity" and tell me it doesn't sound fantastic. The CD master was made from a 3rd generation 1/4" tape. You can hear the rooms' effect on the drums, the guitar, the bass (to a lesser extent) and the vocals.
Now listen to an original master of "Brothers in Arms", one of the first "DDD" releases and while it's a great recording, it's very brittle and dry sounding even though there's plenty of reverb and bass. Compare that to the 5.1 remix of the same album (done in 2005), LOTS of ambience. You can hear the oscillator leakage on the Hammond B3, the room's effect on the voice even though he's very close to the mic. The only technical difference really was the use of oversampling DACs and 24-bit 96-KHz mixdown medium. It was still mixed on an analogue console, mixed to digital, mastered on analogue equipment to digital. Of course it's a modern master so it's so heavily compressed, the volume actually drops when the drums start. Very dissapointing but whatever.
On a final note, the specs that digital pushers advertise, they REALLY cheat. They use a 1KHz sinewave digitally generated at -.1dB or so to test the S/N ratio and distortion. But the reality is, you NEED to keep your levels around -18dBfs or so to keep both the electronic and digital componants happy and this really changes those specs.
Prior to oversampling digital converters, people said digital sounded harsh even though Ole' Harry said it was fine.
I think digital is probably 95% of the way there. That last 5% is simply making the high-end performance available today affordable for the masses.
This is why when I work in the digital domain, I think very carefully about my poison. If I'm making very steep corrections (narrow Q), I'll lean towards linear EQ because otherwise, narrow Qs tend to introduce a lot of phase distortion. However, with wide Qs, phase distortion is not a huge issue and thus I'll use starndard Infinite Impulse Response EQs to avoid pre-echoes.
Cool thread BTW, I love discussing this stuff and hearing other people's ideas.
But when it's real bad, I try to break out the linear-phase multiband. That sounds horrible, but used right, it's an EQ that's only on some of the time
It's because I suck!In fact, he gave, what I would call one of the no-bullshit, straight forward answers on the subject, not only with regard to using the highest sample rate possible but also the alternative to use a half track, high speed open reel deck.
You can very easily find a half track deck [not necessarily a revox], a mic and tape for less than $500. Even with minor servicing, it'll still be within budget.
Sorry to have edited out much of your tech talk, about sample rate and such but I too had a very hard time discerning the content.
Analog doesn't use sampling [its 'sampling' is effectively infinite] & therefore it is future proof;
Analog is the superior storage medium by far
Analog will outlive [as it already has] every technology past and present
Analog is the easiest and most intuitive technology to master
To put into perspective, a tape recorder from 2 decades ago, with some TLC, maintenance and attention, will continue to not only be serviceable, decades from now but will also be able to outperform and outlive every technology, at least for our lifetime.
This has been done, with laughable and disingenuous results. Case in point, it was used successfully, over the past decades, to discredit and destroy analog recording and it still continues to this very day. That is a travesty.
Regards, Ethan
Thanks Tim, An interesting read.
What struck me quite strongly was the statement that "women ...getting 37.5% right".
If the 2 sampling rates were indistinguishable then we would expect a 50% correct, 50% incorrect answer.
Back to the women.... If they were able to tell which was which 37.5 of the time then they were detecting a difference 12.5% of the time! The sign does not matter. It is still a detection.This is worse for those who say there should be no detection....
--Ethan
I see no reason for being afraid of the ruth.I hope those who disagree with some aspect of the tests get to it and set up their own. Why be afraid of the truth, which ever way it comes out?
You can feel things, but since the OBJECTIVE TRUTH is what you "really" after, than you must recognize, that feelings do not provide you with the truth. That is not to say that there's something wrong with expressing you feelings.I feel that for some people who for so long have strongly asserted a view, the real problem is not to do with audio but ego and saving face before their friends. It gets to a point where backing down gracefully is too much of an embarrassment, and so one sticks to "the party line" because it's easier than admitting one has been wrong, and for such a long time.
Hmmmmm. Looks like mshilarious ignored "medical advice". That's cool. Be it so. So why bother to even going through 100s lines of waffling? - Good question.mshilarious said:Feel more flattered, as yours is the ONLY post thus far to actually address technical issues.
There's even BETTER news, which may be actually a NEWS for mshilarious, and it is that there is one more "category of viewers of specifications" - those who ALSO KNOW what those specifications DO NOT MEAN, those who actually have some knowledge about what knowledge actually is, where knowledge comes from and where knowledge is applicable.mshilarious said:The good news is, I guess, from my experience the uninitiated can't understand specs, and the more knowledgeable know what they actually mean.
