A Reel Person
It's Too Funky in Here!!!
Dogs...
Dogs can hear ultrasonics!
So with all due respect HFC are perceived and thus the question becomes not if they are detectable but one of how significant are they....
And how much of it is aurally available during analog reproduction.
Thats begging the question....
But to answer "none" in digital (cd's) and quite a bit in tape.
Also, come on! Here is a paper that shows humans do perceive above 20 kHz. Let's put to rest the myth that we do not. We are talking about scientific truth here.
Step up to the plate and say "Humans perceive above 20 kHz and I do not know how significant that perception is. That is a scientific truth."
APL, MSH, help you folks are the champions of scientific and technical facts (no wait, I'm a Research Systems Engineer so I am too!) and will not allow the facts to be ignored and mis-information to go un-challenged.
But we're listening to a CD! How can the analog grooviness be something that's within the 20-20kHz bandwidth?
Anyway, ultrasound is really a separate topic.
Exactly. So I wonder why it gets dragged into this thread about analog vs digital.
If the criterion is super wideband response, digital audio recording (even using magnetic tape) creams analog magnetic because of one crucial factor ; inductance. A little detail called a magnetic tape head. Direct analog type recording stretches the magnetic head to its electrical limits already. Add a few more octaves and we have problems.
Regardless of the Redbook CD, these days, even home recordists can buy a modest PCI card that is basically flat to 80khz (I have one).
If ultra wide band is people's bag (personally I think they are misguided) then I'd say definitely go digital recording.
Cheers, Tim
Are we pretty much agreesing that the analog magic is not ultrasound?
Actually we are not agreeing this.....
Before anyone gets their feathers up let me continue.
"Ultrasound" was not the cause in the paper per se. It appeared to me that the authors noted that there might be a detection mode in humans but also that the interaction of the ultrasound and souunds in the "normal" hearing range of humans.
Further, I'm noting that we are sliding back to mis-information: Ultrasounds don't matter, it's the artifacts of tape that make it sound better etc. We cannot state those things with any degree of certainty which makes them mis-information if stated at a fact. (not picking on anybody here just trying to not slide back)
We have an open conversation at this point in which we are looking honestly at the question "Why Analogue and not digital". We have bashed through some older thoughts as to how digital worked and tossed the false aside (do we need to rehash that?)
So let's move forward and not lose the gains we have made.
"Ultrasound" was not the cause in the paper per se. It appeared to me that the authors noted that there might be a detection mode in humans but also that the interaction of the ultrasound and sounds in the "normal" hearing range of humans.
I really, really wish I had a TSR-8 with dbx. And I wish it had needles instead of LEDs. I love needles.
you can calculate exactly how much error is possible in the algorithm.
The idea is to be able to blindly expose the subject to three versions, the live through the signal chain, the digital reproduction, and the analog reproduction.
Do the R2Rs make clunks and whirrs when you're trying to record in the same room as the deck? Like when you punch in and out and stuff?
Would you mind telling him he's mistaken, that yes, people record at 96khz but not to improve the resolution at 20hz or even 1khz but much further up the audio spectrum. Since he apparently respects your views, maybe he'll believe it coming from you.
You can exactly reconstruct a waveform with frequency content up to half the sampling frequency.
this experiment showed that it is indeed possible to recreate a waveform accurately
digital distortion sucks.. but i love overdriving a tape.
laser stylus error correcting cartridge on my turntable
The math that the plugins use is perfect in the sense that they give the exact same results every time.
No, this experiment shows that you can't trust FFT measurements. In both examples, there's obvious displacement in the time AND intensity domains seen as the conical formations that should be single, needle thin lines in this case.
You can reconstruct it, but it won't be the same as the original. The higher the resolution, the more accurate, but it's NEVER an exact reconstruction unless you're using pure digitally generated sine waves. Hardly a real reflection of music.
