Oh, well, I won't push it because I can't find that article. But I will say that the day I believe that Katz can hear and ID the difference in aliasing products between the different sample rates alone the way he claims in that last post is the day that I believe that Haley Joel Osmet really CAN see dead people.
G.
More than one high-end converter designer has said that if you hear a difference between 44.1k and 96k, your converters are broken.
That would be the difference of your converter at the two sample rates. It probably isn't the sample rate that makes the difference (especially in the low end), it's what your converter sounds like at that rate... there's a difference.not exactly "hi end converters" but i just (like yesterday) got a echo audiofire 2 in the mail, for some location stuff.
most reviews of their conversion are good.
any way.
the setup of the software control panel makes it easy to swap between sample rates in real time.
i was sitting and talking into an sm57-RNP
and swapping between 44.1 and 96k the difference was huge.
no, i'm not trying to be cool here, i'm sure anyone could have heard it.
difference mostly in the low end (to my ears) sound at 96 was much more "focused" and could has possibly be described as a little thinner.
but the difference was as plain as day.
it's brand new, and seems to work as advertised. i don't think any thing is wrong with it, or at least i hope not
maybe i'll record the test (the same way) at both sample rates and see if NL5 will host the files (in a aiff of something)
am busy, but will try to get it done as soon as possible.
p.s. is NL5 still around?
That's the funny part of audio production. We work so hard to capture and process our music with the highest fidelity... and 95% of listeners use earbuds and iPods.I get confused on, not only MP3, but all these "media players" too...are they all the same because they sure don't sound the same,imo?
24/48...then to MP3, then to some crap media player...then to![]()
Or desktop computer speakers.
maybe the industry will go to an even lower quality sound than MP3!They're already trying a successor to CD and to all PCM schemes altogether with the SACD and DSD formats. Efforts are also being made to find an agreed upon losless compression format to replace MP3.like Victrola's,to reel to reels, to mono to stereo albums, to 8-crap, to cassette, to digital cassette to minidisc, the CD, the MP3 players...to 24/48 players?
or will it get worse!maybe the industry will go to an even lower quality sound than MP3!
This one is either for Tom, Massive, Fairview or for the experienced engineer in general...
Just throwing it out there for discussion:
If someone wanted to hear the difference, beyond a reason of a doubt, couldn't you just take 2 copys of the same waveform, one at the target sample rate and one at a downsampled rate, align those and flip your phase switch?
Whatever dosn't cancel out reveals whatever is missing in your signal? Perhaps whatever isn't audible would reveal itself on a spectragram or spectrum analyzer of some sort?
I do not claim to be in the same class as those boys, but here's how I see it...If someone wanted to hear the difference, beyond a reason of a doubt, couldn't you just take 2 copys of the same waveform, one at the target sample rate and one at a downsampled rate, align those and flip your phase switch?
Because the $100,000 question isn't whether one track makes a difference, but what is the cumulative effect of having the recording and all of the plug-ins processing 88.2 verses 44.1.
LeeRosario: not a bad idea. if you have no signal difference you have a reasonable but not conclusive proof. If you have differences they could be attributed to the software used to downsample.
This is why I suggested sampling the identical source twice. This way one insures all they are comparing are the actual sampling process.Also true. I'm not sure how you can get around this issue entirely. Before experimenting as suggested, we have to be sure we are measuring the correct "thing".
Tom, I am stuck with my pants down on this one unless/until I can find that article so I can see if there's a different IT-based angle altogether - which I seem to remember - which would be point-in-the-process independent, or whether I'm just remembering or interpreting that paper incorrectly. Until then I'm really stuck in neutral on the topic and will defer to you the benefit of the prevailing wisdom on this issueG. There are some posts by Dan Lavry that may help to clear up some of the issues you were bringing up. It's confusing I know. The points that you brought up seem to be contradicting what he is saying here. But again, the difference is are we talking A/D D/A conversion or basic DSP processing.
The truth is that most people can't even hear up to 20kHz; I've seen evidence of this in hearing tests on many subjects. There is some debate, however, if we are able to sense this HF information and if we can, whether or not it affects our listening experience.
