dualflip
Audio Engineer
Ok, so i was messing around the other day with some sessions, i made some tests mixing inside the box with premium plug-ins such as Waves SSL, API, URS and Bomb Factory. Then i mixed the same song but in an analog board (im not telling you which one, first i want your opinions then ill say which board is), now is worth mentioning that all the compression used for the analog mix was done inside the computer, meaning, only EQ, and levels where done in the analog console.
Here are some drumset files, in m4a, they are titled Drums A, and Drums B:
http://www.soundclick.com/util/getplayer.m3u?id=6940751&q=hi
http://www.soundclick.com/util/getplayer.m3u?id=6940763&q=hi
Next two files are an extract from a metal song, same procedure as with the drums, but this time the analog mix was bounced to 1/4'' 2 Track tape at 15ips.
http://www.soundclick.com/util/getplayer.m3u?id=6940783&q=hi
http://www.soundclick.com/util/getplayer.m3u?id=6940788&q=hi
So which one do you think sounds better A or B?
