Mark7
And, yes the one you saw is more expensive than the four you cited originally. But, it's also multi-pattern; whereas they aren't.
glynb said:Thanks Mark7. Checked out the site and looks interesting.
Wonder how it compares with the rest?
Here are the technical specs if anyone is interested...
Self Noise: 14dBA Comes with shock mount and case.
billisa said:The self noise spec is one I look at. 14dba is very good. I wonder of the single pattern version is similar?
Coming with a shock mount is good, because you reallywill need one. You will also need a pop-shield (for popping p's).
[/B]
Lastly, any condensor you get will pick up EVERYTHING -- including the hard-drive whirring noise on your VF160. The 160 is a very quiet machine, but the mic will pick it up 20 feet away, along with every other little sound.
[/B]
Also, don't leave your condensor out all the time. Put it away (mine are in glass jars) with gel packs. These can be very sensitive to dust and moisture. [/B]
It's a long story... but yeah, the cheepo condenser mic's are made in China.glynb said:Someone elsewhere has implied that all these cheepo condense mics are all made in the same '747(?)'factory in China, and implied that that was a bad thing.
What is it with this story, anything in it?
glynb said:The cheaper version (single pattern?) is 16dba, so that's worse right?
Is the shock mount to prevent noise vibration spoiling the recordings, or just to prevent damage to the mic?
Hmmm, this is bad news and something I hadn't thought of. The fostex hard drive is slightly noisy, but the big problem is my compressor which makes aloud humming sound, very noticeable. The current sm58 mic doesn't pick up any of this, because I have to mic up real close which masks out any extraneous noise. Ah well, I'll just have to learn new techniques to get round the problem, maybe encase the compressor in a box or something!
So that's why they go on about having a free case with it and so on, i wondered what the big deal was there!
glynb said:I have decided finaly to upgrade from my sure sm58 to a condenser mic for recording vocals and acoustic guitar on my fostex vf160 multitracker. What would be a good low cost upgrade in my position which would deliver improvements on the sm58?
I don't want/can't afford to spend a lot!
(The vf160 has built in pre amp's BTW)
Mark7 said:One is probably the pad switch (that'll be the one with a -10, or something like that, on it), one's probably the low cut switch (there should be a glyph that looks like a slope rising to a plateau) and the third one is probably the Pattern Switch (it should be a three position switch with three glyphs: one for cardioid (kind of kidney shaped), one for omni (a circle) and one for figure 8 (guess)).
