Somnium7
Noise Criminal
I am planning to buy a handful of different hardware compressors for various uses. Some advice and suggestions would be greatly appreciated.
Here are the different tasks:
Here is a little more detail. The Bass synth is a poly synth and I use it mainly for Unison Basses where the level changes drastically as the oscillators drift in and out of phase with each other. It goes from clipping inputs to getting lost in the mix.
The lead synth is almost always run through a distortion box. Very hot signal and mostly just needs a limiter.
Vocals are female (alto & second soprano) and will mostly come from ribbon or high quality dynamic mics.
My console has send and receive on each of it's four busses and I use the busses as stereo pairs. On the busses I'd like something dual-duty that can work well on an entire mix or just a single track. A friend with a small studio has recommended the dbx162sl as the buss unit and swears up and down that it can do it all. However, it's pretty pricey for me....
- Analog Bass Synthesizer
- Lead Synthesizer
- Vocals
- Bus insert/Mix
