		stijnijssel
Yoyo,
I have read a LOT of threads in this forum but i had a really hard time finding the right product which suits my demands which are simply:
- USB in
- A good headphone amp (loud enough to drive a high impendance headphones like 300 Ohm)
- TRS 6.3 mm jack outputs to go to studio monitors
My setup is a 64 bit laptop with Windows 8. And i am currently using Apple Earpods (IPhone 5) as mixing monitors , which i simply plug in to my laptop. (Don't Laugh ) I must say the sound quality isn't THAT bad , but lacking detail i think ( for instance below 50 Hertz) But now i want to make this big upgrade to finally experience real sound quality for my productions in Ableton Live.
I am planning to buy:
- Equator D5 studio monitors (they have TRS 6.3 mm female, unbalanced inputs)
- Some room treatment
- Sennheiser HD600 headphones (300 Ohm) to check the bass on.
In the beginnning i thought i could just plug the equators into my 3.5 mm headphone output, but i read that that is like throwing your sound quality in the trash.
I also read that i need an Amp to drive the HD600's otherwise it would not go loud enough.
My budget is low (under 160 Euro's / 200 $)
I think what i need is an ''DAC w/ balanced outputs''. I don't need inputs for mics and hardware synthesizers right now , but if the device happens to have them as an extra, it would be nice for the long term.
I did a lot of research and people seem to give the best reviews on :
- Focusrite Scarlett 2i2 ( People sadly say it has a low power output so it cannot drive the HD600's properly)
- Steinberg UR22 ( Some people say it is better than the 2i2, but some people say it has an annoying low frequentie rumble on the background (also when the gain is 0. but it seems that this problem accured on a limited number of ur22 leaving the factory . Other people say it has an annoying pink noise when raising the volume)
My questions:
- Does anyone have experience with high impendance headphones using the 2i2? Is the volume of the headphones output THAT low or is it just that you are not going to be deaf listening at full volume? I dont want to be deaf so i wouldn't mind a limit where i do not get hearing damage. But i wouldn't waste my money on a device which doesn't suit my demands.
- Is the Steinberg UR 22 The way to go or does it have some noticable noises in the background?
- Other suggestions/ comments?
Your help would be appreciated,
Thanks in Advance
- USB in
My questions:
Thanks in Advance
 time will tell how they sound for me
