D
djclueveli
i'm tryna to calibrate my DAT with my mixer so where to i find a 1kHz line-up oscillator? and how do i hook it up and perform test?
What are you trying to calibrate? Just watch the meters on your dat to get the level.djclueveli said:i'm tryna to calibrate my DAT with my mixer so where to i find a 1kHz line-up oscillator? and how do i hook it up and perform test?
djclueveli said:yea i hooked the mixer up to my sound card using the rca (red n white cords) running from my mixers REC OUT into the sound blasters line in. is that the right way to hook it up? man i dont even know how to make the sine wav to begin with LOL. can u just explain the steps i needa take in sound forge to do this so i wont keep bothering u over and over LOL. thanks
It's easier to visualize the signal flow if you say that you connect from the line out to the mixer. (follow the signal flow, it's less confusing)djclueveli said:i connect the rca cable from my mixers 2TRIN to my sounds blasters line out (the green one) and then with the master fader and the 2TRIN fader set to zero,
TexRoadkill said:The last thing you need to be worrying about right now is level calibration.
Set the windows fader at unity (0), plug the output of your sound card into the mixer. Set the master fader on the mixer so the meters read 0db. now set the record levels on the DAT machine so the meters on the DAT machine read -12db.djclueveli said:so i go to my windows mixer and pull the analog mix down? man im confused. OK this is my gear.
Yamaha Mg 10/2 mixer
Sound blaster audigy 4 soundcard
shure ksm27
i just need someone the process to me without skippin any details. i already have the sine wav downloaded. now i'm seeing pull down the level meter than i'm seeing pull down the input meter lol im confused.
When did I say anything about setting the windows levels?djclueveli said:ok so now isee. so to get the windows recording levels to -12db,
NO! There is no singing or microphones.djclueveli said:do i have to sing into a mic to reach 0dbu on my mixer
