Whats your recomandation?
  • Thread starter Thread starter Nakatira
Nakatira
Nakatira
That Norwegian Bastard
I`m moving into a new house.
I`ve got a even shaped room to put up a studio in.
On the side of this room I have this small bedroom\shed.
I was thinking about making it a controll room.
The roof is slooping after 1,5 meters into the room.
total floor size is 4,5 meter x 2,5 meters
Full height is 2,25.
I`ve made some drawings.
So my question is Should I drop it and setup the controlls\monitors in the Music room instead (its much bigger).
I just thought it would be good to get the controlls isolated from the rest. :)
I think I would use the little room for a vocal or iso booth. That ceiling is gonna reflect the monitors right into your head, so either way you'd have to completely deaden it.
Thanks for the quick reply :)
I was planning to try some DIY acoustic treatment.
when you say deaden it.
I`ve deaden a few rooms before to get that 70`s prog rock sound.
I used a whole bunch of thick carpets floor carpets, wool blankets, you name it.
If the room was completely dead, It would be worth a shot?? :confused:
I was planning to set up Acoustic panels, but if carpets would do the trick I have some experience with that.
thanks.. .... Daniel :)
No I don't think carpet will do. You would need 50mm of rigid insulation on all the walls, and probably 100mm in a few spots. I don't have experience recording with a room like that, although my old house had one bedroom almost exactly those dimensions. Personally, I wouldn't have tried using it as a control room, but maybe somebody else here has something to add.
I'm a bit lost here. Are the two rooms actually separate as of now. And if they are It's useless to use one as a control and one as a live room because if they are right next to each other, it is most likely NOT soundproof. And that is a huge investment in itself.
As for your acoustics treatment... I don't know what you did before, but I don't understand how that room you did before with just carpets was dead. carpet is good for really one thing. Being carpet. Some will say that it gets rid of a lot of high frequencies, but then your left with the lower ones which will be of greater affect. go to Ethan Winer's site and read his acoustics articles and bass trap article. www.ethanwiner.com/acoustics.html and http://www.ethanwiner.com/basstrap.html. His traps are cheap and pretty easy to make, and the acoustics article is incredible. I give this link out about once every 2 days on this board and have never got anything but super positive reviews.
Good luck, what ever you decide.
Ben
Ben
Well I will not say that the room I used the carpets on was completely dead, I havent got enough experience with acoustic to say so.
But I remeber doing the Clap you hands test, in the room before and after, and there was a difference, a very noticeable one.
And from the sounds I got on the drum kit, it sounded pretty dead..
The rooms are next to each other.
So I might as well just use the recording\live room for both live room and controll.
and skip the "work on the small uneven room".
Ps the two pics are of the same room, just different angles.
the live room I`ve got is about +25" meters should be enough room.
One more question.
Do you think the Acc panels Will make the drums sound more dry 70`s than the carpets? :) :confused: :o
One more question.
Well yes the rooms should sound different because what you probably did was get rid of all the high echo and reverb in the room. This would become very apparent when clapping your hands. But when cranking a bass amp in there and noticing that it sounds much much different that that amp normally sounds, this is going to be because there is a lot of cancelation occurring at low frequencies. It's not just gonna affect bass. Read the first article I sent you. I doubt that you were creating bass traps with that carpet, unless it was about 5 layers of thick carpet 1' away from the wall. Its your decision as to use the other room as a control room, I like the separation, but then again I already had about 1' of concrete between my two rooms to start with so life wasn't quite as hard.
Ben
Thanks for the reply man.
You`ve got a point on the bass part.
I Just remeber reading somewhere "I think it was in a norwegian magazine" the 70`s were all about carpets.
I will not argue fro the sake of the carpets, instead I look forward to reaching for the tool belt and try some DIY panels and traps.
Lot of great models and facts on the Ethan winer site.
Thanks for the help man.
I'm going to pull out my fire marshal bill hat one more time today... I just want to remind you that buildling codes for floors and walls are different. Carpet is ok on the floor, but because fire climbs, it's not ok on walls.
Not to mention it doesn't really do that great in studio situations for absorbing frequencies. "DIY" acoustic treatment is very tricky. It's more complicated than sticking some carpet up on the walls. :cool:
Good point on the fire danger, I should have thought of that. :)
I`m going to try my best understanding these acoustic panels.
Hopefully they will give me the dead sound that I crave.
Now I read in an other thread that, it was adviced to remove the floor carpet and use a wooden floor, I think it was Mshillarious suggestion.
He seems to know what he`s talking about.
But I thought a carpet floor was helping to deaden the sound?
In the place that I`m fixing I`ve got a wooden floor, as well as walls and the works.
So is carpets a big no no, even if you go for the 70`s bucket drum sound? :)
I believe that you could use that room as a control room. Just swap you idea round, and line the back wall with 4" broadband abosrbers, with 4-6" bass traps in the corners. Also have a broadband absorber on the sides of the room between the monitors and mixing position. (shown in the pics)
thanks for replying
Intresting... :)
It would be nice to separate the live room and the controlls\monitors.
One more thing should I put up carpets in the rooms, or leave them as they are "wooden"?
thanks for the great drawings :)
Nakatira said:
thanks for replying
Intresting... :)
Shouldn't matter too much, 'cause the reflections on the floor from the monitors will just bounce to the back wall to be absorbed anyway. Save your money and keep it wooden. Looks better too.
Why thank you, i get enough practice. I'm constantly(well not constantly, that'd be sad, but you know what I mean) drawing plans etc in paint.
Btw look at my age, I'm only 18, so don't have enough experience to give you a perfect, profession, response. I may be wrong, but I have read A LOT on the subject, so think it is a good solution. People have said the sound isolation between the rooms will not be good. And I agree, BUT, It will be a lot better than tracking and mixing, etc in the same room.
Btw look at my age, I'm noly 18, so don't have enough experience to give you a perfect, profession, response. I may be wrong, but I have read A LOT on the subject, so think it is a good solution. People have said the sound isolation between the rooms will not be good. And I agree, BUT, It will be a lot better than tracking and mixing, etc in the same room.
Well I`m 25 and I obviously know less than you.
Thanks for taking the time to help me, and those pics are saved so that I have a plan to follow once I get started.
Its gonna be great getting behind any wall if you have a drummer that needs 30 takes on one track.
its not sound proof but i helps.
and it sure keeps the computer noise out of the live room
Thanks pal. :)
Sounds like me, drummer needing 30 takes, lol. No problem, hope everything works out well for you.
hehe :D
its times like that the wall your behind keeps your spirit up and your head partially clear.
I`ve done some 30 takes in the same room as the drummer and man your ears are fried.
I will be trying to make those panels soon.
I`ll post some pics or something once I`ve made them (or Died trying :D )
I've never really hard a really good explanation as to why people use hardwood floors in studios, besides that it looks fantastic. I understand that carpet absorbes the wrong frequencies, but a hard floor reflects all frequencies, isn't that just as bad? Wouldn't that create lots of excess reverb? Either way, I still plan on using hardwood floors in my studio so any reasonably good suggestion will work for me. :)
Lol, You know what the panels are? If not, do a search. I'm sure you already have. You seem experienced in the ways of homerecording.
In the few recording scenes I`ve been to\been a part of.
There has allway been a carpet.
I`ve never been to a proffesional studio though.
So it shall be cool to check it out.
even no small carpet under the drumkit :D
Well i hope I do.
Thats the frame thing aint it :D ...
I`ve read a few of the other posts.
Concerining the diy 703 rigid fiberglass .
I just hope I can find that stuff over here in Norway, its probbably around under another name :)
