Hi,
First off all my equipment is budget. Including my pres. I have two DMP2s which are sonically equivalent to the DMP3s and the Omni-Studios if I understand correctly.
DMP3s are $150 for two channels new. Used they are $130. DMP2s aren't much cheaper if you can ever find one. Omni-studios can be had around $100 used.
Still take the DMP3 as an example. That's $75 per channel. Studio projects cost more. Rane cost more. So tell me where I can get a high quality budget pre for $20. I sure can't find it.
Comparing the DMP2 pre with the pres on a cheap mixer board or even the pres on my Fostex VF160 XLR in channels I can hear a substantial difference on acoustic guitar. Whatever mic I use. And the DMP2 pres are so much better than the pres on the little Yamaha mixer board I had that I sold the mixer. I mean what's the good of having it if you're never going to want to plug a mic into it?
On vocals the difference between the Fostex pres and the DMP2 pres is not as pronounced. But on
acoustic guitar the difference is pronounced. Especially with regard to high end detail. And this is what makes a nuanced guitar part shine.
So the way I look at it $75 per channel is the bottom end for pres. Others will have to tell you how much better $500 per channel or $5000 per channel will sound. I can't afford them which is why I'm on the homerecording bbs.
Mics however are an entirely different story. I am sure that $5000 mics are better than $100 mics but good mics are available in any price range. Especially if you do your research and are willing to buy used.
Good dynamic omnis can be bought for $15. Good condenser omnis can be bought for $25. I know omnis don't get no respect but they really are the starting point. Every aspiring engineer should start with a pair of omnis and learn from there. I started with two EV 635s. Excellent microphones in production for over 50 years. I rarely use mine any more because I prefer my EV PL9 and my Realistic 1070 series omnis. For
acoustic guitar I also love my Naiant msh-1stereo pair. Still gallop by on a fast mule and you might not hear the difference between any of them. I would say the Naiants have the best high end detail and the lowest SPL. The dynamics are essentially equivalent except the 635s and their sibling the RE50s have an attenuated frequency response.
The point here isn't to compare omnis but to note that I've just mentioned 5 mics that are truly great mics and all under $50 some I bought as low as $15.
So yes using a good mic is important. Very important. Using an expensive mic, not so much.
Looking at my mic inventory I can see that I have 73 microphones listed. (Ok. I'm a collector and I have a problem getting rid of anything) Two of those 73 cost me over $100, my AT4054 and my Peavey 520i. Most cost under $50. Some free. Some I've had so long I forget but those are all under $50. The ones I use most were $30 a pair.
All of these mics sound noticeably better when going through the DMP2 preamp.
So besides a lot of aimless rambling about my obsession I'm trying to make a point here. Which is.
Good preamps and good mics are both important. But the cheapest preamp I can find that I would call good is $75 a channel. And the cheapest mics that I call good are considerably less.
So expensive preamps and expensive mics are not important. But better to put a little bit of money into some preamps and get by on good but cheap maybe even used mics than to even think about cheap, meaning under $75, preamps.
In a different budget range, like most professional studios have, I have no opinion. I've never owned any of that expensive stuff. I can appreciate why they want it but not having it has never stopped me from making good recordings.
Thanks,
Hairy Larry
