Seeker of Rock
The One And Only
Im getting ready to assemble the charcoal pyramid and get the coals going
Do you douse the coals as soon as you no longer need them so you can dry them out and re-use them? I've discovered you can stretch out the utility of charcoal that way.Pyramidal formation always, same as a campfire
Hard coal works best in that regard.Do you douse the coals as soon as you no longer need them so you can dry them out and re-use them? I've discovered you can stretch out the utility of charcoal that way.
Provided you have an airtight grill. Big Green Egg.Hard coal works best in that regard.
I do. I cover them and close all vents and they extinguish within minutes. Charcoal ain’t cheap so I squeeze every bit I can from it.Do you douse the coals as soon as you no longer need them so you can dry them out and re-use them? I've discovered you can stretch out the utility of charcoal that way.
I hadn't been aware that WD40 make a specific bike lubricant. Original formula is probably better than nothing but there are a lot of purpose-made bike chain lubricants. Bike chain maintenance should also include using a chain scrubber to get rid of debris - road dirt and metal particles from the chain itself.Myth: WD-40 Multi-Use Product should not be used on bike chains.
Fact: While WD-40 Multi-Use Product it is not a grease, it is formulated with strong lubricating oils and other ingredients, and is a terrific product to use for bike maintenance. It does not attract dirt or moisture to metal surfaces – just be sure to wipe off any excess WD-40 Multi-Use Product before riding.
For long-term lubrication and other specialized bicycle maintenance needs, check out WD-40 Specialist BIKE products. Developed specifically for cyclists and mechanics, this high-performance line of bicycle care products is sure to become a mainstay in the toolboxes of bike mechanics for decades.
Lol.“WD-40 MULTI-USE PRODUCT CURES ARTHRITIS!” NO WAY.
Myth: WD-40 Multi-Use Product cures arthritis.
Fact: This popular headline, appearing at least once a year in the tabloids, is completely FALSE. WD-40 Company does not recommend the use of WD-40 Multi-Use Product for medical purposes, and knows no reason why WD-40 Multi-Use Product would be effective for arthritis pain relief. WD-40 Multi-Use Product contains petroleum distillates and should be handled with the same precautions for any product containing this type of material.
I drove down to the El Salvadoran cafecita and the grill is still on the swale but too big to load in my truck with one man. Ima see if my neighbor wants to do some dumpster diving with me later. It has the thick heavy duty grates in good condition. Probably the gas lighter assembly is fried. Perfect for a charcoal grill. Little rough exterior but my little place is a rental and nothing big or fancy, so perfect for here.Riding earlier I spotted a nice big multi level gas grill in a swale out for hard trash pickup. I don’t like gas but it has a nice big charcoal area inside and I could always fabricate or buy a couple of cheap grates. This little $15 mic grill works but it’s pretty fucking tiny
I use those for big grills but mine’s made for children. Plus, I like building my little pyramids. I am the fire king.
And…..score! LolI drove down to the El Salvadoran cafecita and the grill is still on the swale but too big to load in my truck with one man. Ima see if my neighbor wants to do some dumpster diving with me later. It has the thick heavy duty grates in good condition. Probably the gas lighter assembly is fried. Perfect for a charcoal grill. Little rough exterior but my little place is a rental and nothing big or fancy, so perfect for here.
