Drums of Doom!
Okay you asked for it!
After going through literally a dozen+ drumkits searching for "my sound", I wound up Custom building a set myself.
I used Keller Shells, and Lugs and parts I got from Andy Foote at
Drum Supply House.
The Kit is finished in a Satin-Oil Natural hand-rubbed Finish. Looks and sounds incredible!
The Toms are 8-ply Maple. The Kicks are 10-Ply Maple.
The Kick drums have AKG D112's Mounted Internally on MAYEA Mic Mounts, and Hart Triggers mounted inside the Shells on an "L" bracket-which presses them against the Batter Head from the inside. Trigger used to Open The Key on Noise Gates.
The Snare has a Hart Trigger permanently Mounted inside for Controlling the Key on a Noise Gate.
Toms have Remo Muff'ls on them.
Kicks have a King Size Pillow in each.
Snare is "wide-open".
This is going to be a long list.
Depth x Diameter
2 16" x 28" Kicks (Yes, that is twenty-eight, not a typo)
1 16" x 20" Floor
1 14" x 18" Floor
1 12" x 15" Mounted between Kicks.
1 8" x 14" Brass Pearl "FFS" (Free Floating Snare.)
All Toms have Pinstripe Batters with Ambassador Resonant Heads.
Kicks have CS BlackDots(White Heads with Black Dots) on Batter and FibreSkyn 3's on the Resonant side-No holes in Resonant heads.
The Snare has a Coated Pinstripe on Top, and Remo Snare head on the Bottom.
All stands are Pearl's Top of The Line.
Kick pedals and hi-Hat stand are "Axis Longboards"-Legs are removed from Hi-Hat stand. Mounted to Kick with a Pearl Hi-Hat mount.
Sticks are Vic Firth "Buddy Rich" model. (My Favorite for the last few years)
All Cymbals are Paiste
1 14" set of 2002 Sound-edge Hi-hats
1 22" Rude Power Ride (had it since 1981 or so)
1 20" 2002 China Type
1 20" Sound Formula Full Crash
1 19" 2002 Medium
1 18" 2002 Medium
1 18" Sound Formula Power Crash
The following Cymbals are mounted on 1 Pearl Boom Cymbal Stand which has a Mounting Bar that I made from 1" Square Steel Tubing, with 5/16" threaded Bolts serving as the Cymbal posts.(You can buy a 3 foot section of 5/16" Threded steel, which I simply cut into pieces with a Demel Mototool.
1 3" Accent Cymbal
1 5" Accent Cymbal
1 6" Accent Cymnal
1 5" Cup Chime
1 7" Cup Chime
1 8" 2002 Bell
The Following are triggering sounds from an Akai S2000s/e Sampler; I'm using
an Alesis DM5 for the TMI.
3 ddrum Pads (Triggering Tympani samples)
5 triggers that I built (like LP spikes) (Triggering Symphonic Chimes/Tubular Bells)
My Next step, is building a Stage, and threading the Bottoms of my Cymbal Stands, so that they will no longer be "tripods", but will thread into metal "Sockets" in the Deck of the Drum Riser, thereby allowing me to take up less space with the Drumkit.
Sort of Like Neil Peart's Kit is mounted to his Riser.
Tim
[Edited by Tim Brown on 09-18-2000 at 18:30]
