Stealthtech said:
Incorrect.....
yes if you get v6.0 and up....no if you get 5.8 and below which often times can be had on ebay for $100 and less.
No offense, but, while what you say is true, let's be realistic and point out that getting an earlier version of Logic is a dead end path. There is little or no support on the PC side and it's only going to diminish in the future.
This person is new, why confuse them with an option that's really not an option?
Besides, we have plenty of other things we can confuse them with!
Alexandrah- Any of the programs mentioned will record any kind of audio you throw at them. The kind of music shouldn't be a determining factor. HOW you will record makes a big difference though. Are you playing all the parts or will it be more of a band situation? Will you be incorporating MIDI or will everything be done through audio (except the drums as noted earlier)? Are you trying to create radio playable CDs (possibly not a realistic goal depending on your space) or are you recording for fun and relaxation?
Before you start buying things, take some time and analyze what you are trying to accomplish. Define your priorities. Once you start figuring out where you are trying to go, then it becomes a lot easier to draw up a route.
Once you have a good idea of what things are most important, then you can look at your budget. Fortunately, it's possible to make remarkably high quality
recordings with a modest budget and limited resources. When you know how much you can spend and what things are most important then you will be able to narrow the choices down quite a bit.
Once you've accomplished that, then you can spend some time at the store trying things out and asking lots of questions. Of course you can post here and we'll give you our opinions (sometimes they're even useful)
The options can be intimidating. I was out of music for a long time and I was totally lost when it came to computers and digital audio. There is a lot to learn and it changes all the time. But you WILL get there!
Just remember to focus on what your goal is and make your choices based on whether the item will help you achieve it. Try to ignore as much of the hype as possible and look for reviews of actual users as much as possible. They're the ones who know what works and what doesn't.
Another suggestion- On major items like audio software or soundcard purchases, join the user forum or Yahoo or MSN groups, if they have them. These are an invaluable resource for learning about not only the product, but also what kind of support you are going to get.
Good luck!!
Ted
