B
bluesunlegends
Yes, a good (most like very expensive) mic will offer great sound quality.
However, no all of us can afford to buy a 1k+ mic.
Like for example, I can tell when someone didn't used the best mic out there (and did a bad mix) when their vocals seem to be displaced from the the music. You know what I mean?
A great mic (and a good mix) will make the vocals sound like they're intertwined with every part of the song.
So what techniques do you use to make your vocal recordings sound fairly good?
Whether it be the way you sound treat a room, mixing techniques, or maybe just the way you sing into the mic.
I want to know your secrets!
. If the room I'm recording in sounds good, I'll sing about 8 inches away from the mic. Nothing too precise, but just to give some space. If the room is kinda bad, I'll get close to the mic and then later put a high pass filter on the track to fix the proximity effect. I usually compress the vocals to taste of the song and mix. Since vocals are always last in my mixes, I turn the volume of the vocal track down completely and slowly raise the volume on it to find the spot where it sits just right. A little reverb never hurts either, but only enough to barely notice in the mix (unless a noticeable reverb effect is wanted). If needed, EQ can be applied to add a little presence. So, yeah that's pretty much how I do it. It's not elaborate but it works every time for me
