sweetbeats
Reel deep thoughts...
Looking GREAT Cory, very nice! I'm envious of the attenuation you're getting from the walls too, what a nice perk that would be! Curious how much is leaking outside the house? (I'm assuming not too bad at all!)
My wife was wondering that too...I'll likely measure that at some point because I'm curious but I'm fairly certain it is not as good. The windows are a major leak point. The windows that are there have insulated frames and laminated glass so they are better than standard vinyl windows, but I didn't want to do the double-window thing...and on the interior walls there are two layers of the Quietrock (one on the inside of the room and a layer on the other side on all the adjoining walls). On the exterior wall (which is only the wall with the windows) there is just the layer of Quietrock inside and then two layers of 5/8" plywood sheeting (that's another story) and the cement fiber siding on the outside. Its still good, but not quite as good as the Quietrock methinks. BUT, the closest neighbor's house is 75'~100' feet away maybe? I'm pretty sure I could pound on the drums any time day or night and never be a nuisance. Maybe I should measure in the garage too...just one layer of Quietrock there too and then one layer of 5/8" fire-rated sheetrock on the garage side (that wall is the one my son's drums face...the one with the cabinets mounted to the wall) so I'm sure the attenuation is not as good, BUT its the garage and the though the garage is unfinished, the roll-up doors are the steel insulated type and I'm sure the cement fiber siding helps some, and that all faces the street and the closest house thataway is well over 100' away.
