jerzeysk8board said:
My recordings sound less clean and sound more distant for some reason, and thats without mixing or watever. Is it suppose to sound like that before mixing.
The short answer is pretty much, yes.
The "less clean" aspect of it is probably a combination of lack of experienced technique on your part (no fault of yours, you're a rookie, after all!
) combined wth the fact that though you may have bought two or three grand worth of gear, you're trying to compare it against studios that have single compressors that cost as much as your entire setup
. Add to that the fact that you are doing the recording in an untreated or poorly treated sound room - as compared to a half-million dollar acousticlly designed room - and youre style is somewhat cramped in comparison.
All this doesn't mean that you are out of luck and that you *can't* get your sounds as "clean", it just means that acheiving that sound takes just as much practice, study, and work as learning to play an instrument to get "that sound" does. Keep at it; read everything you can on the subjest of recording and mixing (there's lots of good stuff in the music section of your bookstore), expiriment and practice with your mic and recordingtechnique a lot, make some basic upgrades to the sound of your room itself, and you'll get better sounds.
As far as sounding "distant", mu bet is that you're referring to the actual volume levels not being up to commercial CD standards. This is normal at the raw recording stages at which you described. Final volume is not determined and acheived until the last stages of the mastering phase of the production; before then the tracking levels will typically be signifigantly lower in volume on your computer. A peak reading of 0dB (VU) in your analog signal chain does NOT correspond to a 0dB (FS) peak reading on your computer software. Typically (when things are st up correctly), 0dB in your analog signal chain should typically wind up coming in somewhere between -14 and -18dBFS on your digital meter when playing back on your computer (this is a rough average, and can be turned up by the engineer if desired.). This is normal.
The extra "headroom" will be needed as part of the mixing process, and even after mixing, there should still be some headroom left over when ready to master the mixdown.
I agree completly with Punkin. Take it one step at a time. Don;t load up on a crapload of compressors, EQs and other toys yet, especially during the recording process. Learn how to get the "clean" part down first, then you can start learning how to make things un-clean again
G.
