what mics shoudl i use to mic my drums
  • Thread starter Thread starter 14yearoldkid
14yearoldkid
i dont know what mics to buy for my drums. if i only had to pick 2 mics which ones should those be? and where should i put them
thanks
Some good cheap drum mic's are...
Kick... ATM25
Snare... Shure SM57
Overheads... a pair of Oktava MC-012's
I like the 4 mic placement.
With only two mic's... you could go with a kick and overhead mic, or if you have a good sounding room you play in, you could go with two room mic's... and sometimes two overheads can work.
You probably want at least 3 mics to mic a drum kit: 1 overhead, 1kick, 1 snare. Popular choices around here are:
Overheads: Oktava MK012, MXL 603, Studio Projects B1
Snare: Shure Sm57, Sennheiser 441
Kick: Audio Technica ATM25, Shure Beta52, AKG d112
Do a search for drums in the microphone forum & you'll find a wealth of info on these & other mics, and some tips on placement. Also read Harveys 'big thread'(Sticky:How does diaphragm size/polar pattern relate to mic applications? )
You will find very much discussion on the forums about the drum mic subject.
Look also at Fletcher's website http://www.mercenary.com/ for the three mic drum technique.
I once had a killer drumsound with only one $50 Radio Shack PZM (pressure zone microphone) on the right spot.
So, if you're on a tight budget (most 14 year olds are) I guess you'll have to find that 'sweet spot'.
Hope this helps.
yes
yes it did help but i can only use two mics because im getting a tascam mkIII and they dont have enough inputs for ht e drum so how can i get a great soudn with two mics?
Id get a Studio projects B1 and use it as an overhead and an AT ATMPRO25 to use on the kick.....im picking it over a Marshall MXL603 only because it is more versatile in other areas.......that would be my 2 mic choice.....
as you decide you need more mics to do drums, the next addition would be a Shure sm57 to put on the snare.......
next would be a second B1 to go with stereo overheads........
I agree with Gidge on mic selection. You'll just have to spend some time working with mic placement until you get a good balance.
I have to suggest that you look at the FAQ:
http://www.hr-faq.org
That's my job, you see. There's a little more on there than has already been said regarding mic purchasing for drum sets, but it's a good newbie read anyway.
You won't! You might get an acceptable sound though. I would say get an AKG D112 ($200) for the kick and an AT Pro 37 ($140) for the overhead. You are gonna need phantom power for the 37 though and a good pre-amp will help a lot! If you could, I'd say get two of the Pro 37s for overheads... They pick up everything!
ok
but shoudl i buy a mixer and hook it up to my tascam so i can have a larger selection of mics?
Re: ok
This depends on how much you want to spend.
