notbradsohner said:in building one of these
what kind of capacitator would I want for capacitator x? Film, metal, ceramic? Any ideas. This will be my first project, but looks fun.
Those values are kinda big for a ceramic. Poly film would be more typical.
Synkrotron said:yep... sounds right to me... more than likely still polarised at these values (positive and negative connections).
mshilarious said:Nah film caps aren't polarized (probably some exception out there, but generally), perhaps you were thinking of tantalums.
notbradsohner said:does this look like everything I need?
http://www.mouser.com/index.cfm?handler=project._view&projectid=93259
notbradsohner said:those are the parts
notbradsohner said:thanks ms! I have no freakin' clue what im doing!!!! woo hoo. The closest ive come to an electronics project is making drum triggers.
mshilarious said:The chip is the wrong package, SOIC is surface mount, you want DIP instead.
Try this one:
http://www.mouser.com/index.cfm?han...uctid=211539&e_categoryid=289&e_pcodeid=51212
The electro cap doesn't need to be bipolar, just get a standard polarized electro and you'll save a few pennies.
Light said:And make sure you get the polarity of that cap right! The signal voltage will be quite low, so your not going to make the cap blow up, but it won't work if it is in wrong.
