spantini
COO of me, inc.
Since I've retired from the automotive industry, whenever I need to air up my tires I find a gas station with a good AIR/VAC setup (difficult to find AIR pumps with high enough pressure and/or accuracy in these parts - but I found one). Most of these charge $1.50 for about 3 minutes of AIR. Usually, I'll pull in, drop my $1.50 and scramble to get all 4 tires pumped up to spec - sometimes I don't make it through the last one and I have to dump additional funds into the monster for another 3 minutes to get the 20 seconds of additional AIR for that last tire.
This new place I went to this afternoon has an excellent AIR/VAC with a powerful and accurate AIR pump, and it's only $1.00 for 3 minutes. Cool!
So I decided today that I would bring extra quarters and take my sweet time. First, I took the valve caps off the front tires only. Then I dropped $1.00 in and took my time to get the right pressures. Then, with the pump still running, I put the caps back on and moved to the rear tires, where I removed their valve caps - pump still running. I aired up one rear tire, screwed the cap back on and moved to the last tire.
Now I figured my 3 minutes was just about up, so with the pump still running, I dropped another $1.00 in to make sure it would continue to run. BUT!!! - and here comes the learning experience - adding more than $1.00 does not rack up additional time.. you only get credit for the first $1.00 and 3 minutes. Second $1.00 down the drain
Just then the pump stopped
I added yet another (3rd) $1.00 and it started up again giving me my additional 3 minutes.
THE END
THE END
