what is a mixer?
  • Thread starter Thread starter LUTH
L
LUTH
I know this is gonna sound stupid, but what is a mxer?,what is it used for?, after i record a song on a track recorder, do i hook up the track recorder to the mixer and start mixing the songs?, is that what a mxer does?, please someone help me
thanx
No, that's not what you do with a mixer. Most 4-track recorders (or 8 or 16 track) have in built mixer sections. You use these to mix your tracks on the 4-track machine. Separate mixers are just used for routing multiple instruments (or one instrument at a time if you're a lone recordist) either in a live or recording situation. i.e. you plug mics., guitars etc. into the mixer and route them through it to a PA or recorder. Hope that makes sense:)
*PEEP* Wrong!
Seperate mixers are also used in MIXING situations! Not all recording units have a builtin mixer. In fact, the better recorders don't have one. These are standalone expensive units. And you combine them with an even more expensive mixer...
The 4 tracks with built in (analog) mixers that I know, don't really have good mixer sections. But most of them do have an output for each track, so you can hook up a better mixer, with better EQ, insert compressors etc, more aux...
A mixer is just a thing with alot of inputs and alot of outputs, mainly used to get all the inputs on just 2 outputs, in a musical asjustable way. Now that was nicely explained, right?
*Peep* Roel, you are correct sir. You can now proceed to the bonus round. Do you want want's behind door #1, door #2 or door #3?
Yes, I neglected to say that when you route your various instruments through the mixer you also mix them; and I'd forgotten about recorders with individual track outputs:o
Euuuuhh.... Hmmmmm... (Stressing now...)
Door number... euuuh.... 2?
You've choosen the door where Carol Marrow is standing. You've won...........A BRAND NEW ALESIS 3630 COMPRESSOR!!!!!!!!!!!
Really don't have a clue who Carol Marrow might be, but I'm pretty sure I'll find a good use for the 3630...
Fido! Fido! APPORT! shieeeeeeeeeeeeeeeeeeeeeeeeeeew *POEF*
Roel is *so* cool.
A mixer is a boxfull of electronics that you plug your mics into and then run cables from the mixer to your recorder. That's if you're recording.
A mixer is a boxfull of electronics that you use after you've recorded your tracks in a couple of possible ways:
1) Well, you can use it to mix down. You run the track you've recorded through the mixer, and adjust the level or EQ. Or, you stick an effects unit (like reverb) in there and use that to refine the sound of your song.
2) You use the mixer only to listen to what you've recorded. You do all your mixing down using software, and don't even *look* at the mixer. You snigger at the mixer. You chuckle in the general direction of the mixer in an independent, possibly superior, possibly even derogatory way. "Ha, ha! You mixer!" you say.
But then u also have a MIXER in your software package...:D :D :D :D :D
Here's one:
and what do i use to connest everything together, like the mixer to the track recorder, is it 1/4 jacks?
thanx
One use of a mixer not mentioned is to get a bunch of microphone preamps cheaper than you could buy them separately in mono or stereo configurations.
Cables are cables. It's the ends and the holes they fit into that matter. Take a look at your mixer and your recorder and see what kind of holes (jacks) they have. The only time (pretty much) you'll actually need to use TRS 1/4" plugs would be to use the channel inserts.
But, like they say in old war movies, "Smoke 'em if you got 'em."
Depends on your multitrack recorder.Both my reel to reel and adat xt20 have rca ins and outs, and the adat also has a elco connection which I use.So,for the reel to reel I bought rca to 1/4" snakes and for the adat I have a elco snake.If your using a little portastudio and it has direct outs there probably 1/4" otherwise your L/R outs are probably rca.Just look at the back of it and be prepared to spend some cash on good quality cables!!!
"and what do i use to connest everything together, like the mixer to the track recorder, is it 1/4 jacks?"
Probably. Everybody here's right, but here's a summary of possible plug types:
1/4" plug
1/4" stereo/TRS plug
RCA plug
XLR plug
Check your mixer and recorder jacks to see what you need.
just 2 confuse the russians...
+ the 1/4" plugs can be
.) unsymmetrical (tip, ring - a simple mono chord)
.) symmetrical (tip, ring, ring - looks like a stereo cable)
=> for everything with rca you take the unsymmetrical ones
=> for connecting 1/4" with XLR or 1/4" with 1/4" you better go for the symmetrical ones.
right dobro?
One thing everyone has leftout so far is that the job of a basic mixer is combine sources into one output.
The simplest mixer will have two inputs and one output. But that isn't very usefull.
One of the more common uses for a mixer is in live sound. A mixer is used to combine the signels from the mics and feed them into an amp. Most PA amps have line level inputs and most mixers have line level outputs but mics have a very low output. So the first job of the mixer is to get the signel up to line level using the preamp. Next the mixer usually has some sort of eq so you can tweak the sound to make it sound better. Then you have a fader which lets you control the level of the signel that is mixed with the other signels coming into the mixer. Then the signels come together on a buss and from there it goes on to the output and into an amp.
"right dobro?"
That's right. I think we should confuse the Russians every chance we get.
btw i LIKE the russans. My ex-girlfriend was born in russia and they are one of the funniest and kindliest folk i've ever met.
... just to ensure that noone gets this spell wrong ...
