P PokerDude422 New member May 26, 2006 #1 Ive been reading up on recording techniques and I keep reading about how I should use a mic pre amp. What exactly is it and what does it do?
Farview Well-known member May 26, 2006 #2 It takes the small signal from a mic and amplifies it to line level. Line level is what all the other equipment in the studio runs at line level.
P PokerDude422 New member May 26, 2006 #3 is it neccessary for recording if you can edit it to be the right level on the computer?
bennychico11 ... May 26, 2006 #4 PokerDude422 said: is it neccessary for recording if you can edit it to be the right level on the computer? Click to expand... every mic will need a preamp. the stock sound card on your computer has a "mic in" with a generic preamp in it. The output level of a microphone is too low for your gear to use (and your speakers to reproduce)...so you need to boost it louder.
E EndangeredFeces New member May 27, 2006 #7 PokerDude422 said: Ive been reading up on recording techniques and I keep reading about how I should use a mic pre amp. What exactly is it and what does it do? Click to expand... A MIC PRE IS A NECESSITY!!! NOT AN OPTION!!!
J jonnyc New member May 27, 2006 #8 EndangeredFeces said: A MIC PRE IS A NECESSITY!!! NOT AN OPTION!!! Click to expand... There's no reason to get excited like that. What he needs to do is go read tweak's guide and take his final exam. www.tweakheadz.com check it out.
P PokerDude422 New member May 27, 2006 #9 thanks for the tweak link ill check that out, and i am still kinda confused on the pre amp thing, is a soundboard considered a pre amp or what?
bennychico11 ... May 27, 2006 #10 PokerDude422 said: thanks for the tweak link ill check that out, and i am still kinda confused on the pre amp thing, is a soundboard considered a pre amp or what? Click to expand... anything that has an amplifer in it can be considered a preamp. it amplifies the signal BEFORE passing it on somewhere else. A guitar plugs into an amplifier Your speakers have an amplifier in them Microphones need an amplifier
P PokerDude422 New member May 27, 2006 #11 bennychico11 said: anything that has an amplifer in it can be considered a preamp. it amplifies the signal BEFORE passing it on somewhere else. A guitar plugs into an amplifier Your speakers have an amplifier in them Microphones need an amplifier Click to expand... well thats pretty simple, thanks
