bennychico11
If the offset is really excessive, ie. more than a few percent, you would filter right after sampling. Otherwise, the less you have to filter, the better, especially when the goal is a truthful sound.
And in case, the offset comes from effect processors in the chain during mixing, you only could handle it afterwards anyway.
Are you saying fix it after you've mixed it down to a stereo file or on the stereo bus?
I still say you fix it once you see it. Otherwise you're robbing yourself of headroom as you mix before it even hits the stereo bus. A hi pass filter set extremely low isn't going to affect anything of significance to your sound...especially if you can set it 20Hz or below. Heck even if you can set it to 10Hz it'll fix it. And if you don't like filters, use a DC offset tool.
