R
realestninja
What does DC Offset mean?
thanks
thanks
Normaly you won't. Any offset should be killed during mastering. Offsets can be side effects of cheap ADC's and are also a comon side effect of many effect processors. If you have a subsonic filter (which also kills the DC offset) involved, it should be placed late in the chain just prior limiting and dithering.So why would I want to offset it?
anyone seen a DC offset that moves the wave DOWN?
just curious....why is it always up?
you'd want to eradicate that offset by introducing an offset of -5v.
A negative DC offset would merely mean a negative constant DC voltage. So a negative offset can exist.
If you have a DC offset in your audio signal, what is the problem? Does it make AD/DA conversions produce errors?
I got nothin![]()
Why ?
Normally you wouldn't on purpose.So why would I want to offset it?
It's best to really reduce it as soon as you see it....
In a waveform editor like Sonar or Cubase, the waveform will look normal except that it's center will be shifted upwards or downwards (usually upwards) off of the center (-inf) line in the waveform display. Or, if you record with no signal on the input, you'll see a flat line go across the display riding above (or below) the centerline.What will it look like?
If the offset is really excessive, ie. more than a few percent, you would filter right after sampling. Otherwise, the less you have to filter, the better, especially when the goal is a truthful sound.and not wait for the mastering stage like LogicDeLuxe said
Scary. I'm scared.
