sjjohnston
CDR
"Big Kahuna's" 24 million bit, 96 billion Hz machine would be pretty exciting, although it might put a bit of a strain on your storage medium. Let's see, 715,255,737 gigabytes per second ... that's 682 petabytes ... a 3 minute song would need 122,782 petabytes of storage, even before allowing overhead for error correction. Might this exceed the entire world's data storage capacity?
On another topic, I'm not sure I agree with the "always use high bit rate recording," though I suppose it doesn't do too much harm (if you've got a lot of huge file servers sitting around). Sure, I suppose if you're recording something to a multitrack for further processing ... but what about a mixdown that's "final"? If you're not going to do any processing (and you don't need a lot more than 100 dB signal/noise ratio), I don't see why you shouldn't just record at 16 bit and be done with it.
The rest of the answer I've quoted talked about sample rate more than bitrate, but I don't know that the virtual of 96 kHZ has really been established, unless you're recording music for bats.
Of course, if you want high sample rates, how many oxide molecules fit in 15 (or 30) inches?
sjoko2 said:BigKahuna:
"1- The best resolution you can record at is 16bit/44.1khz .. which for most people is more than adequate .. afterall, that is the standard for CD. Even if your master was 24,000,000bit/96,000,000khz ... it would have to be converted to 16/44.1 when the CDs are made anyway."
If you have access to higher bit rate recording, you should always use it, despite the fact that CD's are 16/44.1....
