You don't understand it better than I do and there hasn't been a single thing you've said that I wasn't aware of.
Enough ...... I think you're over reacting and I don't agree that a small amount of foam like that is a danger.
 Though you SAY you're not for a nanny state ... you completely contradict that by implying that people aren't able to read the fact that I specifically said that using very much of it would be dangerous.
But .. no ..... if we allow any at all ..... then some poor stupid person might not understnad that I really mean only a small amount and oh my God, we have to protect them from their own stupidity.
You're wrong ..... period ..... there is NO code requirement that people can't have packing foam in their house ..... there is NO code requirement that people immediately take packing materials out of the house.
If you tried to run that stuff by about just anyone you'd get laughed out of the room.
Do as you wish but to immediately carry packing materials out of the house is an over reaction and WAY fearful.
Dude
Why do you think that all these tests exist (note especially the tests for things like mattresses -  furniture, vertical cloth fabrics, soft foams, etc., etc., etc. that go into homes) - home furnishings and treatments are required to meet certain fire and smoke standards,  do you suppose all these tests are there just for grins and giggles?  And this is only the tip of the surface,  this doesn't include any of the testing established under NFPA requirements and standards.
Flammability and Toxicity Testing
ASTM
C542 - Flame propagation
ASTM C1166 - Flame propagation
ASTM D56 - Flash point by tag closed tester method
ASTM D93 - Close cup flash point
ASTM D229 - Method 1 - Burning rate, Method 2 - flame resistance
ASTM D635 - Burning rate in vertical position
ASTM D1929 - Self and flash ignition temperatures
ASTM D2584 - Ignition loss of cured reinforced resins
ASTM D2843 - Smoke density from the burning or decomposition of plastics
ASTM D2859 - Flammability of finished textile floor covering materials (methenamine pill)
ASTM D2863 - Limiting oxygen index (LOI)
ASTM D3014 - Flame height, burning time, loss of weight for plastics
ASTM D3065 - Flammability of aerosol products
ASTM D3675 - Surface flammability of flexible cellular materials
ASTM D3801 - Comparative extinguishing characteristics of solid plastics in a vertical position
ASTM D3874 - Ignition of materials by hot wire sources
ASTM D4804 - Flammability characteristics of non-rigid solid plastics (Methods A and B)
ASTM E84 - Surface flammability characteristics of building materials
ASTM E136 - Behavior of materials in a vertical tube furnace
ASTM E162 - Flame spread using a radiant panel
ASTM E603 - Full scale room burn test
ASTM E648 - Critical heat flux of floor coverings using a radiant panel
ASTM E659 - Auto ignition temperature of liquid chemicals (AIT)
ASTM E662 - Optical smoke density
ASTM E681 - Flammability (explosion) limits of chemicals (UEL, LEL)
ASTM
E800 - HCN, Hydrogen Cyanide measurement using the colorimetric method
ASTM E906 - Heat and visible smoke release rates
ASTM E1317 - LIFT - Lateral flame spread
ASTM E1321 - Material ignition and flame spread properties
ASTM E1354 - Cone Calorimeter
ASTM E2058 (FM 4910) Screening Test- Screening test for clean room test
ASTM F814 - Smoke density for aerospace applications
AITM 2.0005 (7.1.6) 60 degree flammability
AITM 2.0008 (7.3.3) Optical smoke density
AITM 3.0005 (7.4) Toxicity
ATS 1000.001 - Flammability, smoke, toxicity, and heat release
BELLCORE GR-63-CORE - Telecommunications equipment fire resistance
BIFMA X5.7 - Furniture flammability
BMS 13-48 - Smoke and toxicity
BSS 7230 - Flammability testing of aircraft materials to FAR Part 25, Appx F, Part 1
BSS 7322 - Determination of heat release using OSU
BSS 7324 - 60 degree flammability, smoke, and toxicity
BSS 7238 - Optical smoke density
BSS 7239 - Toxic gas generation
CAL 106 - Resistance of a mattress or mattress pad to combustion from smoldering cigarettes
CAL 116 - Cigarette test of upholstered furniture
CAL 117, Sect A, Part I - Flame retardance of resilient filling materials used in upholstered furniture
CAL 117, Sect D, Part II - Cigarette smoldering screening test for bedding
CAL 121 - Flammability test procedure for mattresses in high risk occupancies
CAL 129 - Flammability test procedure for mattresses for use in public buildings
CAL 133 - Flammability test procedure for seating furniture for use in public occupancies
CFR vol. 16, 1610 - Std. for the flammability of clothing textiles (45 deg. angle test)
CFR vol. 16, 1632.4 - Mattress flammability
CPAI 84 - Tent fabric flammability
DIN 4102, Part 1, Class A1 - Ignition (only)
DOT 173.338-18(b)(7) -Flammability using a red hot platinum wire
FAA/FAR 25.853 - Flammability tests
FAA/FAR 25.855 - Flammability tests
FED STD 191A, Method 5903.1 - Flammability of cloth in a vertical direction
FED STD 191A, Method 5903.2 - Flammability of cloth in a vertical direction
FMVSS302 - Automotive interior flammability
HALOGEN CONTENT - Determination of the halogen content level
IEC 331 - Fire characteristics of electrical cables
IEC 332-1 - Single wire/cable flame propagation
IEC 332-3 - Wire/cable bunch flame propagation
IEC 695-2-2 - Fire hazard testing; needle flame test
IEC 754-1 - Evolved combustion gases of wire/cable
IEC 754-2 - Acid gas
IEC 1034 (1,2) - Smoke density of wire/cable
IEEE 383 - Cable tray flame spread
IEEE 45 - Cable tray flame spread
IMO A.652(16) - Upholstered furniture flammability test
IMO A.653(16) - LIFT - Flammability of marine surface finishes
ISO 4589-2 - Determination of burning behavior by oxygen index
ISO 5660 - Cone Calorimeter
ISO 9705 - Room burn facility and modified (1/2 scale and 1/4 scale) room burn
MIL 2031 - Fire/Toxicity tests for composites used in submarines
MIL C-24643 - Acid gas
Mobil 45 deg - Flammability test calculating weight loss for rigid urethane foams
MSC.41(64) - Smoke and toxicity products of combustion
NES 711 - Smoke
NES 713 - Toxicity
NES 715 - Temperature Index
NFPA 225 - Surface flammability characteristics of building materials
NFPA 258 - Optical smoke density
NFPA 264A - Cone calorimeter
NFPA 701 - Flame resistant textiles and fibers
NFPA 1971 - Flame resistance of cloth in a vertical direction (Fed. Std. 191A, Method 5903.1)
Room Flammability Tests - 12'x12'x12' (adjustable ceiling height)
SMP 800-C (Modified) - Combustion toxicity
UL 94 V Series - Vertical flammability
UL 94 HF Series - Horizontal flammability
UL 214 - Flame propagation of fabrics and films
UL 723 - Surface flammability characteristics of building materials
UBC 8-2 - Full scale room burn test
