WDM and DMA drivers, how do i get to them????
  • Thread starter Thread starter weatherbill
W
weatherbill
Do I have to do anything to activate WDM or DMA drivers in windows XP???? Is there a little box to check for activating these drivers, or is one automatically there and the other needs to be activated and if so, how do I get to them in win xp????
win xp ships with native WDM drivers for Soundblaster cards, possibly for others but I'm not sure which ones. If you put in, say, a soundblaster Live, you get WDM drivers install by default.
You need to specify your sound card. Try visiting the manufacturer's website. If they have any WDM drivers available, they will probably have them there to download.
You should have been able to tell if Sonar is taking advantage of WDM drivers when you first started. It should have said that it needed to perform a test on your hardware. Then a box would have popped up saying something about WDM. If that didn't happen, then you don't have a WDM driver for your soundcard installed.
Also, make sure that "Always use MME interface..." is NOT checked under Options/Audio/Advanced in Sonar.
I was having problems with my MOTU in Sonar, and I downloaded the latest WDM driver and it made a world of difference.
