J
jerzeysk8board
im exporting audio from recording, i can choose between 128-320 kbps, wat does it do to the audio and which would give the audio best quality?
jerzeysk8board said:can all devices play at 320 k, like ipods and other items, or it only effects the size of the file?
It is commonly called bit depth because it is bit depth, not bit rate. The word rate tells you that something is being measured against time. Bit depth doesn't have anything to do with time. It is and will always be bit depth.cpl_crud said:The second use of the word "bit rate" (which is the one that you're likely to hear about on these forums) reffers to the "depth" of a digital recording. It is also commonly called "bit depth".
Only in video is this the "standard" rate. (notice that this is a rate because it has to do with time.)cpl_crud said:The "standard" pro recording rate is 48kHz.
