VST System Link...Inputs from both computers???
  • Thread starter Thread starter Beyond
B
Beyond
When using the system link, can you use the audio inputs from computer one, but actually record them on computer two?
If possible, I want to use the inputs from both computers, but only record on one.
Thats a bit vague mate. I think what you are asking is can you use the audio inputs on one computer but actually record the audio onto the hard drive of a second computer. The answer to this is yes.
How are your computers connected??? ADAT or SPDIF?? I will make the assumption that you are using SPDIF from the question. In this case it will not be possible to record two instruments at the same time as one set of inputs is connected to the outputs of the other computer in order to establish the system link connection. Therefore only one set of inputs is free.
if you are using soundcards with multiple outs then you should have no problems recording with both computers at the same time.
Hope this has helped :)
Keith
rax2112
Replies
9
Views
336
E
T
Replies
7
Views
985
ecc83
E
T
Replies
4
Views
537
TalismanRich
TalismanRich
C
Replies
8
Views
708
PitchTempoAndriy
P
