Vocals to dynamic? Compressing 30dbs...
  • Thread starter Thread starter BBad199
Ahh, the happy middle road where I will wholeheatedly second that. Distressors are awesome for about anything.
In Tune Audio said:
If you want the best sounding vocal, you need to fix it before its recorded.
Try teaching the guy some proper mic technique. Move in comparison to the mic, depending on his volume.
As was mentioned before, record each part individually.
Also, what are you doing while he's singing? You should be watching your levels. Ride your faders and adjust as you go. That's essentially what compression is (In a very very general sense).
The less things you have to add to your signal chain the better. Fix it on the way it. Don't just sit and twiddle your thumbs while people are performing.
I'm suprised it took so long for someone to say this. There is no fix for a shitty track. Have the dood do it again and again untill it sounds good WITHOUT ANY processing. Then you can do your job. :D
