Lets say I'm sitting in front of
the dm2000, what I do is track everything first, or if I don't have too much time, I'll record the first vocal, and while they sit there practicing for 5 minutes on the overdub, I start mixing down the main vox by first compressing the vox usually 4.1 compression, and -3 to -5db threshold, move the attack/release to their levels, and then I might give it BEARLY a touch of delay & reverb. Then it's off to recording the second main vox, doing the same thing.
Depending on what artist I'm working with, will depend on how many vox tracks I will lace. For Weatherman for instance, the usual track count is 3 main vox's + fill-in's, 2 adlibs, sometimes 1 harmony. so around 6. I also keep the tracks all separate of course... well the fill-ins' would be merged with each of the main vox's so that I only have 3 mains 2 adlibs 1 harmony. Then I'll proceed to say the adlibs, those are usually panned left or right, added some reverb onto it, depending on how many adlibs and if they were doubled or not. If they are doubled, and sound thicker, than I'll add a decent amount of reverb to it. If not I add a touch of it instead. btw, I'll compress all the vocals. I'll also pan maybe 1 main vox and lower down the volumes of all tracks a tad bit. I don't want 3 main vox's fighting each other, so I keep 1 at a good level, and the other 2 I'll lower them slightly, until they are almost barely noticeable. also, all the verbs & time based effects are calculated out & timed with the instrumental.
Also during these steps which are somewhat not in exact order... i'll EQ 1 main vox & 1 adlib & 1 harmony (if harmony is added). Lets say I'm eq'n 1 vox & 1 adlib. The adlibs I tend to boost some of the low end, at around 120hz, and the at around 180-200hz i'll use a sharp Q and get rid of some of the muddiness. That'll also allow a notch for where the instrumentals can sit at. Also on the main vox, I'll boost a little on sharp Q at around 5khz, and depending on how the performance is, I'll either boost or cut around 12-15khz. If there's too much sibilance's I'll cut some out.
Then, I'll hit the copy button on the dm2000, and copy the main vox eq's and paste them on main vox 2 & 3. That way I don't have to go in there and mess with too much and start from scratch... That's why I love
the DM2000.... I'll do the same with the adlibs too. Then it's off to see how it sounds all together... Which usually sounds decent, but I always come back into each individual track and tweak it because each performance is not exactly like the one before. While I'm mixing down to CD, I'll study the adlibs, and maybe at some break in's or whatever i'll turn up the effects and let it delay into the next phrase and turn them back down quickly. Breakin' the vox in & out of the instrumental so to speak.
These steps depend on how much time I have during mixing... The longer the time, the better it is of course... I hate mixing stuff down very quickly, unless I do it just to hear how it will almost sound.
