P Stew said:
what do you mean by absorb upper frequencies an reflections?
If you don't know what auralex does, then why did you buy it? We can hear between 20-20000Hz, which means between 20waves a second, and 20000waves a second. Bass frequencies are 20-around 500 or so, mid 500-8000, and high 8000-20000. Auralex will absorb well at mid and high frequencies.
Vocals can reach down to around 300Hz though, so these will be heard over the rest, 'cause any above around 500 will be absorbed. Between 300-500Hz the sounds are "muddy".
Now for your isolation problems. A 1 leaf booth wont do much for isolation, as the sound outside will vibrate the material, which causes theair inside to vibrate, ie sound. So the sound will basically pass right through, even with the auralex, which does nothing for isolation.
With a 2 leaf system the sound vibrates the outer leaf, this vibrates the air inside, which is then absorbed by the insulation, and only a much lesser amount vibrates the inner layer, which vibrates the air inside (This is only when the layers are decoupled though).
You booth will only isolate against high frequencies, because the higher frequencies have much less energy and cannot viberate the mass so much.
Ohh and reflections is just the sound bouncing off the wall and coming back, ie echo.
