Vikash Moleman - Fantasy (2019) ❤️
  • Thread starter Thread starter Vikash Moleman
V
Vikash Moleman
Hello Everybody...
I Made This Song Recently...
I Also Participated With The SpinninRecord Weekly Charts With This Song...
What Do You Think About Fantasy ?
Vikash , I'm having a Lot of playback issues with this one. Its' studdering and popping and sounds like its' clipping pretty bad thru most of the song. I had to turn my volume way down . I think the song may have been uploaded Way too hot for any kind of audio streaming conversion. Its' hard to comment on the actual song with all the audio problems , I don't think its' on my end. maybe you could repost another mix.. mark
For the first half of the song, that reverse pump got really annoying. I almost turned it off. Then when it changed and got more rock, it sounded better, but a little too squished in the middle of the spread. I'd pan out the elements more, and perhaps see what is cluttering up the 400-500HZ low-mids. Might be a bit dense there. Then after we changed to pop, it sounds a bit better. Here, there's a kind of brittleness in the highs... almost like the 1.5-2k range is being pushed/compressed too much. Might be the stock sounds you're using. Not sure.
Musically, I think this piece isn't bad, but it could probably use some diversity within the chord progression. There's a lot of repetition that is noticeable. Repetition isn't bad as long as elements are added and/or changed along the way to keep things interesting.
Not a bad track! Thanks for sharing!
https://homerecording.com/bbs/general-discussions/mp3-mixing-clinic/vikash-moleman-nightfall-2019-a-403056/#post4522593
Thank You For The Response...Yeah The Mix Was A Little Bit Messy But Bydeway Thanks For Liking My Track
