using soundforge to...
  • Thread starter Thread starter gatezk
G
gatezk
create a bass track.
ive been told that i can take a sample and create a bass track for it using soundforge.
"smooth the sample repeatedly n then maximize the bass" this created a nice effect, but not the booming sound i wanted.
are there any other suggestions for creating bass tracks in soundforge?
You probably could, but it would be extemely tedious and you'd end up doing it a million times to get it right.
Get yourself a $5 copy of ACID Music2 or FruityLoops instead.
Using SF is kinda like trying to kill a mosquito with a sledgehammer --- wrong tool for the job.
Cheers.
cool man..
ill try acid instead... i got 3.0... but i still dont see how using a loop program is going to allow me to create a bass track for a sample.
ill do some experimenting..
thanks man... peace
gatezk said:
create a bass track. ive been told that i can take a sample and create a bass track for it using soundforge.
Maybe you're asking the wrong question. You don't want to use Sound Forge to create a bass TRACK, I think you want to use SF to create a bass SAMPLE or take a bass TRACK and EDIT it.
If you want to create a bass SAMPLE or EDIT a bass TRACK with SF, experiment with compression and eq. SF has Wave Hammer included that is a multi-band compressor, which is the type used a lot to tighten up bass tracks. Try the bass preset and then work from there.
SF also has another compressor and some EQs included, but I would suggest you look into some plug-ins from companies such as Waves and TC.
Good luck.
Stray
