T
TripleM
I use HS 2002.
I've read EQing advice that when you have questions about what frequencies of a particular instrument to boost or cut, that you should use a Parametric EQ to sweep the frequencies and see when they jump out.
With HS's Para EQ, the EQ is a complete process. You have to do the whole track at once. So to sweep frequencies would be quite a chore.
Is there a way in HS to sweep frequencies while listening to the track?
Thanks.
Thanks.
