A
Absolutepower
I'm new to the world of using outboard effects, and just picked up my first one, a behringer v-verb. After doing a lot of research on how to actually apply this piece of equipment, I'm back to square one, and still have no clue how to approach this. I have a couple of questions.
1. Do I need to set it up as a send where I send out the track I've recorded out to the v-verb, and then back into my laptop in order to process a track with it? Should I use Spdif for this?
2. I'm assuming that this can't be used in the same way as a plugin where you just select the track and apply it, right?
If that's the case I can really see how plugins are a lot more practical and easier to use.
One last question. I would like to try using this as an effect while tracking. The problem is I use the preamps in my interface, so I don't see how I could put the signal through the v-verb seeing as it goes right from the mic to the preamp in the interface, and then to the a/d converter to my usb port. Is there any way around all this?
Sorry for all the questions. I'm starting to wish I had never bought this thing.
