Hey punkin, it's true that POD has MIDI capability and you can make a communication between POD & Cakey. So, what they can "talk" each other ? limited. Keep in mind that tt's not quite like plug your guitar into POD, hook POD's MIDI out to HS2002 MIDI in, and record your guitar playing as MIDI tracks...
 It won't. However, you can dump your POD's setting and recorded as "System Exclusive File" via MIDI to HS2002.
Here's the example of using it...
Let say you load a particular "clean" sound in POD. Save the patch. Go to POD's MIDI utillity page (...not sure where and how, I don't own one
Go HS2002, and View--> Sysx. Open the Sysx dialog, and click Recieve Bank (in SONAR it's C button).
Recieve System Exclusive will pop up, select <You start dump on instrument>, click OK, then HS2002 will wait for any incoming data transmited via MIDI. Still with me punkin ? Good...
Back to POD, start dump. If you do it correctly, then you'll see HS2002 recieves ......bytes of data. Name it. Save it as .syx file. Here you finish the first task.
Now, open one of your song, and insert MIDI track assign to channel 1. Can you do that ? good... Now go to piano roll, and insert one note on... say Measure 6. Yes, just one note on measure 6. Whatever the note.
Now, View --> Event list. You now see the note on it below "kind". Double click it, it will open the "kind of event" pop up. Change from Note (under MIDI) to Sysx Bank (under Special). Click okay. Now you've assigned some sysex bank to be called &transmited when the song hit measure 6. Understand the concept ? good... Keep goin'. Did I miss sumthin'
  Oh, yeah... don't be such hurry closing the Event list. Remember, whatever number apear under "Data", it means which bank will be called on that point (measure 6 in this case). Leave it 0 (zero). We'll talk about it later...
Now, go View --> Sysx again. Load the saved .syx into Bank 0 (That's why I said leave it zero...). Can you do that ? Good... Click Output (P button) and assign it to MIDI out port which leads to POD's MIDI in. Here you can tell that your POD's MIDI in now has to be conected to one of those HS2002 MIDI out. Dont click the Auto. Just don't.
Not sure of something ? Change the patch on your POD, just change it... Then click Send on Sysx view,... The POD now must recieve the Sysex, and change it's patch back to the "Clean" sound you've saved before. Now close all view in your HS2002 but Track view... Rewind. Change POD's patch to some kind of distortion or sumthin else than the "clean" sound. Go play the song along with your giutar connected to POD... when it hit Measure 6, it will change the patch in POD to "clean"... There you don't have to stop playing guitar to change it's patch... Can you get the idea ? Great...
Once again, I dont own any POD nor HS2002 (I use SONAR anyway), so I can't tell you much about how to set them propherly, I just explain the basic concept in Cakey's side... Back if you have any difficulties... Hope it helps.
Jaymz
PS, Next time, try
not to double post will ya ?
